flywheel weights wd 45 weight?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: flywheel weights wd 45 weight?
    Posted: 09 Dec 2024 at 2:22pm
weighed some flywheels today  49 wd 60#   37 wc 65#   d17 series 4 59#  , what does the wd45 weight ?    the wc does not have a ring gear but once its machined for a ring gear it will still weight more than the wd flywheel because its hollow under the disc face .    how much does the wd 45 flywheel weight ?   i have been told they are heavyer.      how much weight is to much weight on the crank for my puller project ?    has any one welded the crank side of the wheel to gain a few more pounds        dont have 45 one to wieght
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 3:53pm
I used to make a donut out of 5/8" thick steel bolted to the front of the flywheel. About 12 lbs extra weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 10:36pm
what about putting some wieght on the dampner pulley also ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 6:01am
Unless it is as big of diameter as the flywheel, it won't do much. Might eventually break the snout off the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 8:29am
i guess that s why i have never seen any aftermarket stuff out in the auto world on that end of the crank ,     i probley should just put a single front pulley on this engine and save the double pulley for power steering on my wd
