White smoke
Creggers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creggers Quote  Post ReplyReply Direct Link To This Post Topic: White smoke
    Posted: 07 Dec 2024 at 6:21pm
Have a 82 6080 with 433T.Fuel inj pump was rebuilt some years back, when I installed it all timing was correct,pump marks together and engine set at 18btdc. Tractor was hard start and smoked like hell. To this day its hard starting and smokes like hell,but runs.dosent burn oil,no fuel in oil,new Injectors were just installed 12/6/24. Still smokes,still hard to start. No change. We pulled the tractor from the field today,uncle wants it fixed.smoke minimized. Set timing on engine 18*btdc removed screws for window on pump,lines are together,how can I cure the smoke stack at idle to 900 rpm,pull the gear and rotate the pump 1 full revolution? Please advise,all help is welcome..TIA!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 6:39pm
"Tractor is hard to start and smokes like hell".  So let's establish a few things here to help in your diagnosis. ALL 6080's start HARD on a COLD START. This means after sitting overnite and the engine is stone cold in the morning, that first start-up for the day will be the most difficult. Depending on ambient temperatures, the start-up may require a manifold heater, a plugged in engine block heater or a sniff of starting fluid (ether). If the ambient temp is 60 degrees or higher, it should start unaided from these outside helpers. Once the engine has fired and run until warmed up, it can be shut down and restarted easily the rest of the day. Does this sounds like your tractor?? because this is normal !!!    Retarding the injection pump timing to 16 degrees BTDC will help with the cold-start issue. Pulling the pump gear and rotating the engine one full turn will get you into great big trouble, so DON"T even think about doing that. An old thermostat that doesn't allow the engine to fully warm up to 180 degrees will give you white smoke.  Injectors installed backwards will make white smoke if it has the style that can be installed either way. And far too much idling and piddling around at slow engine speeds will too. That is an engine that likes 2000 RPM or more all the time when in use. So, how it is ??? Normal ?? or not normal ??
Edited by DrAllis - 07 Dec 2024 at 6:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 8:18pm
Dr Allis is correct. Our 6060 requires either the manifold heater or block heater to start easily below 60 degrees. Have been using the manifold heater so far this year as it hasn’t stayed below 32 degrees constantly. She smokes considerably until she warms up. I usually allow it to run at 1,000 rpm for 5 minutes before I grab a round bale. By then the smoke has pretty much disappeared, once fully warmed up its gone. It’s been like this ever since dad purchased it new. It has been a great tractor. My XT and D17 diesel are the same way as far as smoke but do start easier down to 45 degrees.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 1:22pm
My bet is the injectors are installed backwards. The return bolt needs to be towards the valve cover, many people install them wrong because the return bolts are easier to get to when put towards the exhaust manifold, but the injectors will be spraying wrong then. Happen a lot more than you'd think!. Other thing is try adjusting the timing one way or the other and see if it helps. The internal timing marks in the pumps I find can be off several degrees. Balancer could also have slipped, so marks on it would be wrong. If you had it timed 180* out now, it would not have enough power to do any work, and would be slobbering so much it would end up with fuel in the oil. Was it at 18* before it was removed several years ago? White smoke usually means late timing btw.
Edited by injpumpEd - 08 Dec 2024 at 1:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creggers Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 4:18pm
I forgot to mention we live in Texas. Doesn't get cold much down here or for very long. So let's back up to say middle of summer,doesn't want to start easily and can kill mosquitoes in mid afternoon after tractor runs all day long 1800rpm. Things I have changed during the summer,thermostat 180*, added an electronic fuel pump for those long/no start 85* mornings.The Injectors and turned correctly with return line facing valve cover. When pump was pulled, I set everything to book specs. Haven't messed with it today trying to get more education on this issue. So should I try to retard timing? If so do I pull the gear and roll engine back a few degrees and try it then? Or roll in normal direction "advance" timing a couple degrees. I'm listening to you guys yall are the experts at this I'm just along for the ride..by the way this is a stanadyne pump..Thanks Yall!
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 4:27pm
I'd advance the timing to start with, it is sounding like late injection from what I've read so far.
I know it's been some years since the work was done but at the time was it perhaps noted that the engine ran "quieter" somehow despite being harder to start? That'd be another pointer at late injection.
Not familiar with these pumps at all, I'm more into VE pumps here but is there a way to measure plunger lift? If so that can give a more definitive injection start point than timing marks.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 4:44pm
Stanadyne/Roosa Master pumps start better COLD if pump riming is retarded some on an A-C engine. I said you could try 16 degrees BTDC and I meant it. This wouldn't be the first engine I have retarded 2 degrees. You think it starts hard now?? advance the pump timing and it will start harder when cold. I think your pump can be rotated by loosening 2 or 3 nuts and tipping the top of the pump inwards towards the engine, utilizing the slotted mounting holes.  This all ASSUMES that your no-start situation is yielding a lot of white smoke out the exhaust pipe while you are cranking it ?? An electric fuel pump on a 6080 ??? absurd !!! If the outlet to the fuel tank is clean (it may not be) the fuel is fully using gravity to get to the pump. No electric pump is needed  !!! Better check that fuel tank outlet.
Edited by DrAllis - 08 Dec 2024 at 4:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 4:55pm
I defer to the good doctor on this matter! Every diesel I've ever worked on has "liked" more timing but if anyone knows it's going to be DrAllis.
My memory is terrible but I feel like our paths have crossed on this subject not long ago too Doc? If so, I'm sure I'd have been intrigued as to why the AC diesels like LESS timing on startup, but I don't recall asking your opinion on why this is the case. Perhaps the later injection causes less "quenching" of heat from the cylinder when cold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 5:01pm
Some Stanadyne injection pumps on brand X engines are timed much slower than an A-C engine to begin with. A D-21 is a great example of timing and poor starting when cold. The mighty D-21 was timed at 34 degrees BTDC and started hard when cold.  It was at 34 degrees all the time. The next generation of that engine was in the 210 and 220. Their pumps were equipped with a timing advance that allowed timing to be set at 24 or 26 degrees BTDC (memory fails me) and when the engine started advanced up to the 34 or maybe 35 degree BTDC number. Trying to improve cold starting and still keeping the engine performance and tolerable exhaust temps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 5:11pm
Dr is right, except I feel this particular tractor is timed way late for some reason. Mark on pulley wrong, mark in pump wrong? who knows but the white smoke and I bet the smell burns your nose, is late timing. Something is off here. Did it run right before you pulled it off years ago? It's crazy how many pumps come in my shop with the internal mark in the wrong place. Shops are getting sloppy lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 6:23pm
The poster has no complaint on engine HP, which very late timing would cause. Maybe it isn't used in a full throttle/maximum HP situation, so they don't know it's a t**d for performance ???  If the timing is very late, I'm having a hard time swallowing that it has been that way for 40+ years.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 7:06pm
when things wear out slowly a guy might not know what he is really missing in power and noises because a guy gets used to it
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 7:44pm
Early 4.33 engines  had low compression pistons. But around 1980-81 they put higher compression pistons in.   Then again best of memory they went with the 16:1 and the decreased the hole size of the injector to control smoke and improve starting. IF everything is ok except starting and white smoke (whitish gray smoke - low compression) it is just an early 200CI engine - as stated, check injector orientation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creggers Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 8:01pm
Ok Dr.allis,I'll go with the 16*btdc. Do I align the pump marks,pull the gear and rotate the engine till I'm back on #16* btdc then install gear? As far as power goes there really is no big loss of power,however I can tell there is no 93hp there.
Before pump was rebuilt engine ran like a top,no smoke,took some rotations before starting. The smell of fuel is prominent now but no leaks. Sound of the engine is also different..We don't use this tractor like we use to and I'm the only 1 who turns wrenches on it, so I'd like to keep it up to par best I can.. Thanks !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 8:31pm
You need to re read this about 16deg timing....Loosen mounting nuts and twist pump retarded. Nothing about changing the gearing. Injector lines will give that much.
Edited by SteveM C/IL - 08 Dec 2024 at 8:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 9:44pm
Something has changed since the pump was overhauled. Re-check timing to verify where it actually is. Now, I do NOT think you are at 18 degrees BTDC. You are somewhere else. Make sure you aren't at 18 degrees ATDC !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2024 at 10:57pm
Is there a red neck way to check pump timing using port spill while on tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 6:35am
Not easily on the engine. Thinking back, it appears he may have pulled the injection pump driveshaft out the front of the engine?? when R & R ing the pump?? Absolutely no need to do that (remove the starter to gain more room to work) and quite possibly he may be a tooth off in timing, BUT the timing marks in the pump window are still there. The crank pulley cannot shift as it isn't a rubber style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creggers Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 7:18am
Seems the most simple is to try rotating the pump. I went and checked this morn position of pump, There are slots for pump to rotate and seems the top of pump is all the way away from motor. This afternoon I'll try the rotation and get back to you guys, Thanks for all the help so far!! Will be in touch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 7:59am
The only reason to slide shaft and gear ahead to jump teeth is to get it to where you are within the adjustment range of the slots. I've had to jump them a tooth to fix a previous erroneous installation. Move the pump housing on the slots while engine is off, and see how it affects it. No real need to even take window off pump at this point. Good point Dr brought up about 18 after, not sure there's that many marks but the symptoms kinda do indicate something along those lines. Pump and Crank turn clockwise as viewed from the front of the tractor. Where was the pump rebuilt? Some places have great reputations, some have reputation for making huge mistakes lmao!
Edited by injpumpEd - 09 Dec 2024 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 8:15am
Hold on. Did you remove the pump drive shaft from the engine at any time ???
