CA Idle
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: CA Idle
    Posted: 30 Nov 2024 at 7:22am
First off:  Happy thanksgiving to all of my friends in the USA!
With that out of the way, let's talk about my little CA.  Love it and runs like a swiss watch, but I can't get a good low idle out of it.  Low idle seems very fast - maybe between 8-900 rpm (with no tach of course).  Bringing the throttle lever lower basically shuts the engine  off - no decrease in engine speed, no coughing or sputtering.
Throttle response is good and high idle seems to be where it should be.  Carb was rebuilt a few years ago and playing with the low idle screw does not make a difference.  The throttle lever going to the governor does have some wear and slop and I was thinking that might be the cause of its problem, but I am not really sure.  Still 6 volts on points with positive ground and usually starts on the first try.
Any thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 7:31am
Two things. #1. If the throttle shaft itself is loose in the carburetor body, you are sucking air thru that area and they cannot idle correctly. #2. Is the idle speed screw able to hit the roll pin stop that should be sticking out of the carb body ??  I just noticed my new to me D-10 is missing the roll pin, therefore when you try and idle down just a wee bit too much the engine just quits because the idle speed screw is ineffective with no stop to hit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 7:38am
The carb was rebuilt with new pins and bushings, so I don't think it's sucking air.  The engine runs very smoothly through out the speed range.  I have not looked close enough recently for the low idle roll pin.  I will take a look this afternoon and report back on my findings.  Many thanks Doc!
I forgot to mention it is the Zenith carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 8:01am
Mine is a Zenith too. Those carbs used a roll pin stop where many Marvel carbs had a cast ear sticking out for a stop.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 9:17am
At 800-900 the engine is flowing enough air that it is going from the idle circuit to the main jet system.  As Doc stated either you have an air leak or the jet/passages of the idle circuit are plugged.  When the idle screw is turned all the way in the increased air flow should flood the engine. But, as stated you are running off the main jet.
This is about the best idle circuit explanation  https://www.carburetor-blog.com/knowledge-base/how-267-works/  ;
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 9:19am
Too much timing advance will do this, too...   A manifold leak could, but the mixture would be lean, whereas a carbeurator shaft leak would usually not...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 11:33am
Tbran that’s a great source of information. Really good explanation of how it all works. I’m going to research that site for my D14 carb.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 6:02pm
Old car vacuum leak check was spraying with carb cleaner and listen to engine rpm change. Might work on your carb to check for air leaks.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 5:03am
My D19’s roll pin was missing and acted exactly as that.
Blue Skies and Tail Winds
                          Dana
