8050 first place pull
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Topic: 8050 first place pull
    Posted: 28 Nov 2024 at 11:10am
https://youtu.be/Nq_NX0g3eLk?si=lR_81kDqJe2QEN7A
  This is my 16 yr old son placing 1st in the 18500 10 mph class, second time driving.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2024 at 11:30am
Very nice hook and impressive fuel delivery !!!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2024 at 12:58pm
Awesome run! Only his second hook but looks like he has had some seat time to finish a ride like that.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2024 at 7:37am
Great hook. Was that at Howard Lake?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2024 at 8:28am
   He has pulled a 6080 and a D-19 about 8 times in the past, not much field work as I quit farming six yrs ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2024 at 8:31am
    Yep, during the Orange Spectacular, that is a pain to haul so it only pulls a couple times a yr.
Edited by NEVER green - 29 Nov 2024 at 9:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 6:03am
They put on a great pull there, been a couple of times.
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 5:02am
Nice hook!! If that’s a 426 it runs extremely well& dialed in just right!!
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2024 at 9:14am
    It is a 426, lightly ported heads and ex manifold, still running stock turbo, just ordered S 300 turbo so the fuel is getting turned up.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2024 at 6:52pm
I pulled dads ps 8050 2wd out of the field 40 years ago, started to shake and couldn't get it under control. Pulled antiques some years back CA, U. But I am way in the dark here. When you say turned up, how many hp are you creating I assume power direct trans? What range and gear was that pull in, 5th low range, high 2nd? I have 2 8050's that still work daily but to pull the fwa off the ground at that speed is just freakin impressive. Hell of a show for a 40+ year old tractor.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2024 at 8:58am
Leon B MO
   At the moment the fuel pump is putting out 420 cc of fuel, so I am guessing 450 t0 500 hp?????  Normally there would be more flame out the exhaust but the 8000's have that huge air cleaner, leave the cover off, pull the filters and I made a fine screen bag, add ice and lay it in the bottom 1/3, it leaks water till you pull on a hot night, then it quitsWink        The rules state.. no water injection.
  PD is in 4th low, the rpms are turning 3400 so it looks faster.
   What or who was shaking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2024 at 10:25am
Been so long ago. I've learned a bit but my tire pressure was way to high and the track was rock hard. Tired got to shacking so bad I just stopped.
Leon B Mo
