plastic hugger snout points |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Topic: plastic hugger snout pointsPosted: 27 Nov 2024 at 8:30pm |
Anyone know if the points are cast steel or cast iron? Could plate them if they can be welded on. $50 bucks + -
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 726 |
Posted: 28 Nov 2024 at 8:57am |
If I had to guess id say they are steel. Strike an arc with a 7018 rod and you will know pretty quick
If the weld lays dowm they are steel. If it bubbles up they are cast
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 792 |
Posted: 29 Nov 2024 at 8:58am |
Yes they are cast.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2231 |
Posted: 29 Nov 2024 at 11:27am |
Shoup catalog has them, new also.
Leon B |
Unit3
Posted: 29 Nov 2024 at 10:05pm |
I braised welded one back together years ago.
SteveM C/IL
Posted: 30 Nov 2024 at 9:32am |
I can see they are a casting. The question was cast what? Iron or steel?
ryan(IN)
Posted: 30 Nov 2024 at 10:44am |
The note in my system at work says cast point for steel use 71364963V. But that part number supersedes back to 71364963 without the v that just says cast point. I’d assume cast iron.
ryan
Amos
Posted: 03 Dec 2024 at 2:54pm |
I welded AR steel plates on the bottom of a set of mine on a steel snout hugger head. I used ER70SD4 wire in my MIG, they"re still on the head today
