Wd fluids
Tom75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom75 Quote  Post ReplyReply Direct Link To This Post Topic: Wd fluids
    Posted: 26 Nov 2024 at 4:32pm
I’ve changed the hydraulic fluid before on my wd, and I used vp J20a in the hydraulic, transmission and differential. However I recently had the PTO gasket go bad and read somewhere that the transmission and rearmed use gear oil. I thought all areas used the same oil. Do I need to change the trans and rear end to the proper weight gear oil?
Edited by Tom75 - 26 Nov 2024 at 4:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 4:46pm
NO.. you dont need to change.. HYdraulic- Transmission oil is GREAT for all the cavities.. Some wish to use gear lube in the transmission .. that is OK also, but not REQUIRED..
I personally like gear lube in the Final Drive cases... but even that application can be Hy-trans type oil if you wish..
Edited by steve(ill) - 26 Nov 2024 at 4:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom75 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 5:06pm
Thank you!    Reading the manual it gets a little confusing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2024 at 5:17pm
the manual is 70 years old.......... things have changed... oils have changed... Engineering knowledge has changed.
