tach drives
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: tach drives
    Posted: 20 Nov 2024 at 6:31pm
It appears there are two different ratio drives for the alternator drives for the tach. Does anyone have the slower ratio drive set up
phil
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 9:03pm
12 & 45 tooth are the only one I remember on an Allis that's alternator driven.
 I think MF used similar on a few models but no experience with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 10:07pm
pulley size also effects alternator speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 11:50pm
Yes, pulleys differ and can really change speed of alternator.
Sorry, My notes don't have the offset dimensions.
PULLEY SIZES
170, 175, 180, 185 use; a 1/2" belt x 3 15/16" OD x .670" bore.
190, 190XT and F & G combine; a 1/2" x 3" OD x .670 bore.
200; 2 of 1/2" belt x 3 1/8" OD x .670" bore.
D19, 210, 220; 2 of 1/2" belt x 3 1/4" OD x .670" bore.
7000; 2 of 1/2" belt x 3 1/2" OD x .670" bore. wider offset.
6060, 6070, 6080, 7010, 7020, 8010; 2 of 1/2" belt x 3 1/2" OD x .670" bore. narrow offset.
Bigger model 7000's and 8000's use 2 pulleys; 1 narrow offset w keyway & 1 wider no keyway both 3 1/2" OD & use 2 of 5/8" belts.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 5:51am
M F is 14x23 that will change the tack speed I had some like over the years AC is 12x45
