d21 fuel pump
allisqc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisqc Quote  Post ReplyReply Direct Link To This Post Topic: d21 fuel pump
    Posted: 18 Nov 2024 at 1:57pm
I need to remove fuel pump on my d21. To turn engine for timing he have other way than remove starter and turning flywheel with prybar? I Have no space to turn by the crankshaft nut.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 3:55pm
I can usually turn them over backwards with the fan, just push on the belts while pulling the fan carefully.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisqc Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 3:58pm
thank you, I will try
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 4:23pm
Should be a hole under the clutch housing to get a stout screwdriver in there to get on the flywheel teeth, thats the best way ,
Edited by DougG - 18 Nov 2024 at 4:23pm
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 10:40pm
Make sure you tie throttle in wide open position if you pull the pump off…
It will drop the governor weights if that shaft comes out… learn that the hard way and destroyed a pump, and now I will tie that just for peace of mind…
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
