D12 -- no spark
54f250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Topic: D12 -- no spark
    Posted: 08 Nov 2024 at 7:17pm
I bought a D12 at auction. The prior owner said it was running when he parked it in the barn -- many years ago.  I am trying to get it running but I cannot get spark. I have replaced the ignition switch, coil, and condenser -- still no spark.  The engine turns over just fine.
Any ideas of where I need to look next?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 7:29pm
the face of the POINT in the distributor is probably corroded  ( thin layer)....use a VERY FINE piece of sand paper and drag between the faces to take if off... Spray with contact clean if you got it to finish..
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 8:53pm
Check to make sure that you don't have a wire grounding out inside the distributor. The wire that connects the condensor to the points is very easy to have it making contact with the distributor housing.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 9:09pm
Is it an early Model 6 volt, or later Model Ser. II 12 volt ?
Is the Starter Solenoid on the ignition Switch, or a Push Button ?
Have you tested that you have Power to the Points with the Switch ON ?
G
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 5:11am
I prob turn on ignition take screw driver and wiggle between points and you need to see sparks
Blue Skies and Tail Winds
                          Dana
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 7:14am
Take off the distributor cap, and have someone watch while you crank over the engine, It possible the distributor is not turning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 7:39am
These are all good suggestions, but there are many possible causes. We need to know more.
First, how have you verified there is no spark? Is it because it doesn't try to start? Have you grounded a spark plug and verified there is no spark at the plugs?
Have you checked to make sure you have voltage at the coil? If yes, do you have voltage to the points. Have you checked the coil wire (wire going from the top of the coil to the top middle of the distributor)? As Lars said, are you sure the rotor is turning when you turn the tractor over?
We need all the information you can give us to make intelligent recommendations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 1:22pm
I want to thank everyone who shared their experience and knowledge on this issue. My tractor is a 12 volt 1960 (2454).  After Steve suggested cleaning the points I took a points file and cleaned them.  In short order I had spark.  I put the gas tank back on and cleaned and connected the gas line.  It starts and idles just fine.  I can not get it to run at higher RPM -- it sputters with a moderate surge.  I know I can adjust the idle jet but I don't know how to adjust for higher RPM.
Thanks again for the help provided by this forum. I truly appreciate it.
jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 1:35pm
if it has been setting for some time, the main jet might be plugged somewhat and restricting gas flow to reach high rpm... you see th IDLE screw... there should be another screw to adjust the higher rpm flow....maybe on the front of the carb.. normally the screw is bottomed down, then backed out 1.5 turns to start and adjusted from there..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 6:12pm
I will work on it again tomorrow.  I removed the carb some months ago. I soaked it in carb cleaner for a few days and put a new kit in it.
I got almost no response from either the idle jet or the load jet. I found that if I give it about half choke, I can give it full throttle very smoothly. If anything, the engine RPM is too high.
I know I need to work on the carb -- I just don't quite know where to start.
The other problem I have now that it is running is leaks. One step at a time.
Thanks again,
jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 7:23pm
choke half on cuts the air flow in half... thats because the main jet or passage way is half plugged and cant flow enough gas...  use a small wire or torch tip cleaner to run thru the passage ways when you take the jets out to clean the bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 4:40am
Don't forget the choke shaft air seals, if they're gone, you need to compensate, by adjusting the choke position to compensate...Wink
