Disc harrow disc repair
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Disc harrow disc repair
    Posted: 07 Nov 2024 at 5:56am
We've lost another 20" disc to a hidden stump. Disc broke off again leaving the center piece on the axle. New disc is $35 . Just wondering if broken ones could be welded back together or is that a bad idea? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 6:07am
bad idea...
discs will have been heat treated and when you weld them, poof, HT is gone where you welded....
sadly I have 2, 18 or 20" ones here with square-ish  center holes.
found out NOT to put on ground like a volcano  else you get scared to death with the number of snakes inside next day when you pick them up......
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 8:08am
Sounds about right Jay, except for the snakes. Didn't think you had many up north. Thanks
Edited by ACinSC - 07 Nov 2024 at 8:44am
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 9:45am
Its 50/50. Ive seen welding work fine and ive seen it not work. Just accordind to if you want to try itn
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 9:48am
If your soil is not filled with rock, and the stump was a very rear incident you may have some success with a welded blade. As jay pointed out you do lose the heat treating that hardens the blade.
Now that the cows are back in. You will have the best luck with a low hydrogen rod like 7018.
Edited by Ray54 - 07 Nov 2024 at 10:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 10:01am
Thanks guys!
This page was generated in 0.189 seconds.
