7040 fuel/temp gauge
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: 7040 fuel/temp gauge
    Posted: 06 Nov 2024 at 9:32pm
7040 temp gauge reads strait up soon as key is turned on and stays there and the fuel gauge reads empty.  Does this cluster share a ground wire some where?  somewhere both gauges are connected?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 7:28am
Yes, on the back of the gauge is a black ground wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 9:44pm
Thanks Lynn!
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 4:35am
But still its a mystery to me as how to easily arrive at the back of those gauges? Id like to get in there myself. Thanks.
Blue Skies and Tail Winds
                          Dana
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 9:38am
I too am having issues with my fuel gauge 7060.
I would guess my cluster is Ok, my issues started with a fire that spread from the center rear of the tractor forward under the cab.
I assume my ground wire for the fuel sender is where my issue is, yet, when I jumper a ground, it still doesn't seem work
Question:   is the ground on the gauge unrelated to the ground on the sender unit?
IE// two separate wires?
AC7060Pd 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 6:46pm
Yes, I believe that there are two separate wires. I think that the one for the actual sending unit is just a short black wire that hooks to a nearby bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2024 at 8:51am
Thanks, Lynn Marshall.
it's going to be a busy spring for me!
Lots to do, and it seems I fell into a job!
AC7060Pd 1975
