where can I get azenith carb well vent jet
AddictedtoAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AddictedtoAllis Quote  Post ReplyReply Direct Link To This Post Topic: where can I get azenith carb well vent jet
    Posted: 01 Nov 2024 at 10:42pm
Had my carb cleaned by someone that had an ultrasonic cleaner... Got everything back but the well vent jet.
Is my only option to find a used Zenith 13294 carb for an AC 170 and pull the well vent jet out of that? The one I need had a 30 stamped in it.
The places that rebuild carbs/ sell new ones have to get the parts from somewhere right?  All I can find are brand new carbs, rebuilt carbs, or the rebuild kits that don't have the well vent jet.
Thanks in advance for the help.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 5:17am
Try Carfolo carburetors 330-398-1541 he may be able to help, he is a great guy also and will try and help you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 7:34am
If you can find an old Zenith carb from a D-17 or WD-45, that jet, altho maybe a different number, would work just fine. A One-Seventy Zenith carb is kind of an orphan. It is mounted bass-ackwards on the engine, so the throttle shaft is different (and NLA from AGCO) and the air horn inlet is larger diameter too. Venturi I.D. is actually smaller than a D-17 to hold the HP down to 54 at 1800 RPM.
Edited by DrAllis - 02 Nov 2024 at 7:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 7:42am
I believe part number is 251782
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 8:47am
Check with Mike's carb parts  Mikes carb .com  looks like C52-7-30  jet
Post Options Post Options   Thanks (0) Thanks(0)   Quote AddictedtoAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 9:40am
Thanks guys! Really appreciate it!
