Carb rebuilding
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Carb rebuilding
    Posted: 01 Nov 2024 at 6:37pm
Anyone have any secrets as to how to remove the brass jets from cast iron bodies without destroying something?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2024 at 6:50pm
Heat and penetrant , can try heating cast then applying crayon/wax  around brass to soak into threads
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2024 at 8:08pm
I just use a small torch and heat the brass jets, then let them cool right off and they usually screw right out.  The other thing is to make sure your screwdriver blade us a pretty snug fit in those jet slots. Too thin of a blade is what damages them.  I do a lot of carbs in my shop  and have a rack of screwdrivers specially ground to fit most jets.
Edited by Alberta Phil - 01 Nov 2024 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2024 at 9:37pm
thanks guys. wish me luck
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 6:01am
yes, you'll need luck
and......
 ... file a chisel to FIT properly ! Top,sides, bottom of screwdriver should fit 'snug', NO slop, NO give. Spend an hour if you have to, far better than destroying the jet and learning  a LOT of new '4 letter' words !!!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 6:07am
Several years ago, Dick L had a post on here that he removed the float, partially disassembled the carburetor, then put everything but the float in a pan of water with some dish soap and boiled the carb to clean it.
I have done this several times and I really like it. I take the carb out when it is hot and immediately remove the brass fittings.
As Alberta Phil said, a screwdriver that fits is the secret. I would add this is a place to use good quality screwdrivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 7:40am
YEP... boil it in hot , soapy water... try to remove... if not loose, boil longer... Save the torch for later as a last resort.
