WD45 Saginaw three point hitch
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Saginaw three point hitch
    Posted: 31 Oct 2024 at 1:11pm
Will a Saginaw three point hitch that is mounted on a WD45 fit on a D17 Series I?
Edited by twinson - 01 Nov 2024 at 11:30am
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 4:26pm
If by Saginaw 3 point hitch you mean the one that looked like the Allis original 3 point adapter I think It would work. Never tried that, but I have an original Allis 3 point conversion that I have used on both my CA and my D14, and it worked fine on both tractors. I have a D17 also, but it came with a homemade 3 point on it. But just by looking at it I think it would work if it works on the WD.
Good luck, and maybe someone else on here who has actually tried it on both tractors will chime in. But it worked great on my 14.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 9:48pm
It all depends on how it hooks up. Mine bolts to the hitch hanger brackets, and as I understand the D17 is wider.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Dave76 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave76 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 11:44pm
I have a saginaw 3pt on my 45 and it will not fit on my series 3 D17. I don’t know if series 1 is the same as series 3.
This page was generated in 0.043 seconds.
