WC engine Built to WD45 |
deanvanommen
Topic: WC engine Built to WD45Posted: 30 Oct 2024 at 12:57pm |
Can a early WC engine be built to a WD-45 by changing crank pistons and rods? I have seen some puller tractors that have used the WD45 crankshaft but was not sure what rods and pistons they used?
DrAllis
Posted: 30 Oct 2024 at 1:03pm |
WD-45 crankshaft (1/2" more stroke) WD-45 pistons (and new sleeves) WD-45 manifold and carburetor will get you WD-45 HP. Cylinder head is a little different (taller) but that isn't a HP issue.
deanvanommen
Posted: 30 Oct 2024 at 1:06pm |
Will I need WD-45 Rods as well?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 30 Oct 2024 at 1:43pm |
no but i think 45 rods are precision vs shimmed like WD-WC. A little handier
DrAllis
Posted: 30 Oct 2024 at 1:57pm |
Don't think you can stick WD-45 pistons in an old WC/WD sleeve. When the piston hits the old sleeves ring ridge, you'll break the top ring or the piston itself.
DrAllis
Posted: 30 Oct 2024 at 3:42pm |
Also need a WD/WD-45 governor spring to increase engine top speed about 100-RPM's.
wjohn
Posted: 30 Oct 2024 at 9:38pm |
How early is the WC engine serial number? I have read that the first couple of years of production had smaller diameter rod journals. I haven't been able to find much documentation about this but I probably just don't have an old enough parts book. I have seen different bearing part numbers.
Were the rods physically different or did they manage to just change bearing insert thicknesses?
wjohn
Posted: 30 Oct 2024 at 10:07pm |
Aha, I did enough digging and was able to find it in the AGCO parts books. Looks like anything before engine # WC-13665 had the 2" diameter bearings/rods.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 31 Oct 2024 at 6:36am |
WC block is too narrow for WD 45 crank and rods to clear , even a early WD block is too narrow .
DrAllis
Posted: 31 Oct 2024 at 7:19am |
I'm afraid I'd have to disagree with that. The latest WD block is actually a little better than a WD-45 block for 5+ inch strokes. My puller WD block had a 5.375" stroke in it without any issues. Never seen a WC block that wouldn't take a 45 crank, unless you are talking about that very early WC engine with the 2 inch rod journals, of which I have never seen one.
Edited by DrAllis - 31 Oct 2024 at 8:03am |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4145 |
Posted: 31 Oct 2024 at 9:00am |
Ignorance is bliss apparently. When I rebuilt the engine in the NF 45, didn't have a good 45 block so I used a WD block. Tractor it came out of was around 70xxx serial, I think. Like Doc mentioned, pullers look for WD blocks in a certain serial range.
Fred in Pa
Posted: 31 Oct 2024 at 11:20am |
It is what it is , had a Customer bring me a WD engine and a 45 crank , rods and pistons ,was not enough room in that EARLY WD block for crank to turn around with rods on it. He got a later WD block and there was enough room .
Edited by Fred in Pa - 31 Oct 2024 at 11:26am |
deanvanommen
Posted: 31 Oct 2024 at 11:47am |
Thank You all for the insight and tips. My Engine S/N is W32781K. The tractor belonged to Grandpa and never left the farm, so I know it is original. Has been parked for 39 years, my fault, but I wanted to rebuild and perhaps upgrade the engine. Not sure I could hand crank a WD-45 engine if I built it. It needs an overhaul since the compression is 30-60 at best.
DrAllis
Posted: 31 Oct 2024 at 3:52pm |
Thinking back to the early/mid 1980's, I installed a WD-45 crank in a 1939 or 1940 styled WC. I wasn't too keen on the idea, as it had a long plate affixed to the block on the carburetor side from getting froze up one time and cracking the block. Someone had made a long plate with a gasket and drilled a dozen or more 1/4" holes and threaded the block to accept them. The customer insisted on using that block, so we did. Nothing fancy. M & W pistons and sleeves from a WC/WD combined with the WD-45 crank, we had 220-240 psi cranking compression. Ran good and never had any issue with the patched block.
Fred in Pa
Posted: 31 Oct 2024 at 4:58pm |
My customer was told by many it would work ,he came to my shop so I could show him NOT in this block .There is always a first for everything .
Edited by Fred in Pa - 31 Oct 2024 at 4:59pm |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88633 |
Posted: 31 Oct 2024 at 5:29pm |
does the "FIT" depend on which connecting rods you use ?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5164 |
Posted: 31 Oct 2024 at 6:15pm |
Maybe your customer should have gone to someone that knew how to put in in. I've known of many that have done in. Some were not even professional mechanics.
jvin248
Posted: 31 Oct 2024 at 6:34pm |
. Upgrade the manifold, 10+15% boost? It's important and an easy mod. Add that governor spring for a little boost. Just keep the engine otherwise stock. Do farm work with it regularly. Interesting mod on a couple of B's and WD for otherwise stuck engines: harbor freight preditor engines. If your engine is stuck. .
SteveM C/IL
Posted: 31 Oct 2024 at 11:22pm |
I'm going out on a limb here but I think the rods are alike being that the rod isn't the problem. Those early blocks must be narrow. Wonder if they took different pans?
SteveM C/IL
Posted: 31 Oct 2024 at 11:25pm |
Hand cranking a 6.5-1 WD45 compression would be tuff enough let alone some 7.25-1 D17. Unless you're trying to make a puller it would be more reasonable to just rebuild it as stock WC..
Edited by SteveM C/IL - 31 Oct 2024 at 11:28pm |
