Square copper tubing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Square copper tubing
    Posted: 29 Oct 2024 at 10:48am
I need a source for 10mm and 12 mm square copper tubing. I will need several feet of it. Not having any luck other than short pieces. I have to bend and solder these parts. Any help appreciated. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 11:21am
like this ??
maybe talk to them about 'feet' of it, though may be pricey due to special run !!??
or keep asking Google......
or make a 'jig' to magically transform round tubing into square
or go back to drawing board and redesign whatever the thing is to use COMMONALLY available products ??
I know about the last option. idiot 'engineer' refused to rework his 'jib crane'. Can only get 2 parts per section of steel tubing, results in 6 FEET of scrap !!! Tweak the design and you get 3 pieces with 3" scrap. sigh....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 1:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 3:29pm
Just out of idle curiosity, what are you making out of it?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 6:55pm
me too !!!!
also just how are you going to bend it ? tar or ice ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 8:11pm
Hey guys, I need metric to modify some existing inductor heaters. They are metric from start and I can cut and splice in new modified inductor to their current needs and save the bases they have. These were made in Germany. I can bend them on my Diacro bender once I make the  rolls and die to suit. I saw the suppliers you guys came up with, but really need the metric to save me a lot of work. Any help is always appreciated. I thought Armand might know of a place, he mainly uses brass though. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 8:36pm
