Crank Grinding
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Crank Grinding
    Posted: 05 Nov 2010 at 9:17am
Hello,
I have been making more progress on the 160 that we have in the shop. Since my last update I have removed the three pistons and the cylinder sleeves.
Now with the crankshaft in the open it looks like the surface is worn on the first and third cylinder. The bearing surfaces also show wear and discoloration.
I measured the crank and it is still within original spec with a diameter of 2.2487, I'm assuming my best course of action is to have the crank ground and order oversize bearing surfaces with my rebuild kit.
What is the going rate for crank grinding. Asking because I can buy a rebuild kit with a new crank for about $150 more than the basic kit without and was considering going this route depending on cost.
Here is a picture of the crank:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:01am
If that is the worst journal, I'd try a simple polish first, then just check to see if standard bearings  can still be used.  Otherwise a heavy polish job and .002 under bearings may work if they are available.
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:16am
for a 150 more i would get the crank a machine shop will charge you close to that just to pollish it at least up here in NY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:30am
Do you have a recommendation for how to polish it? I'm willing to spend a little time messing with it if it saves me from needing to get the crank ground or replaced.
Erik
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:32am
That was my thought, figured I would check though.
Erik
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:54am
I would take it to a machine shop and get them to quote me a price .  Cranks can be turned to correct problems for more reasons than a undersized journal . jmho
This page was generated in 0.052 seconds.
