CA BEARING FOR DROP BOX |
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Topic: CA BEARING FOR DROP BOXPosted: 22 Oct 2024 at 8:24am |
For a CA BEARING, CONE AND CUP for CA Allis drop box on rear right side. Part numbers would be appreciated.
Part numbers for off the shelf would be appreciated. numbers 24 and 25
Edited by WD45 - 23 Oct 2024 at 8:37am |
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Mikez
Posted: 23 Oct 2024 at 7:31am |
Do you have better discription of which bearing
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88637 |
Posted: 23 Oct 2024 at 9:26am |
These are the numbers i used on rebuilding a couple "B" tractors... I beleive the CA uses the same..
Rear Axle top pinion shaft
Differential seal 1.250-2.004 .468
lip seal CR12458
steve(ill)
Posted: 23 Oct 2024 at 9:32am |
prices vary drastically depending on Manufacturer...
steve(ill)
Posted: 23 Oct 2024 at 9:34am |
Mike, these are the inbd and outbd BULL shaft bearings on a CA... if you GOOGLE the part number for the outbd it comes up with 370/362 .... and not 368/362 .. ??? not sure why ?
![]() ![]() Edited by steve(ill) - 23 Oct 2024 at 9:39am |
WD45
Posted: 24 Oct 2024 at 8:38pm |
Thanks everyone for your help. Now to get it apart.
