Cast iron valve cover and oil pan WC
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Cast iron valve cover and oil pan WC
    Posted: 21 Oct 2024 at 6:07am
What WCs or other models came this way from the factory?
http://lonsallischalmers.com
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 6:31am
As far as "other models", I have a 42 (wartime) steel wheeled B that has cast iron valve cover and oil pan.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 6:36am
My '48 WC has a stamped steel valve cover and oil pan. I also have what I believe is a pre WW II  WC engine and it also has a stamped steel oil pan and valve cover.
Edited by Phil48ACWC - 21 Oct 2024 at 6:41am
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 1:03pm
I have two cast valve cover and pans, than one on a 57 Wd45.
Don’t think the 57 originally had a cast pan though…
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 6:31am
I have a war time C with cast iron valve cover, oil pan, and cast iron oil pan on each final. So is the cast iron thing a war time install?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 8:30am
I think that's right Lon. Very early ones may have had them too?
I have an iron pan around here for a 201/226 I'm going to put on if I ever get around to building another engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 9:08am
the story is that STEEL plate was at a premium during the WAR and was restricted to that use... Cast iron or Cast steel was not as important... Companies tried to SHIFT some of their STEEL parts to CAST to help the war effort.... when the war was over, MOST shifted back to steel plate for parts.
CS_IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CS_IN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 10:47am
What about the WC stamped steel rearend during the war instead of the normal cast iron?
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 12:58pm
All 18 1933 WCs and up to about 700 something (?) ‘34’s had cast iron valve covers and oil pans.
