303 Baler PTO shaft removal
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 303 Baler PTO shaft removal
    Posted: 20 Oct 2024 at 9:06am
How do you remove the PTO shaft from the flywheel? I suspect taking apart the U joint would be the easiest, but don't know how they come apart.  The shaft got bent slightly so it will not telescope.
Thanks in advance!
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 9:38am
Taking apart the u-joint may not help. You still have the remaining 1/2 of the joint attached to the flywheel.
I’m not familiar with the 303, but removing any shields/guards, looks for a ‘set bolt’ or maybe even a bold that goes all the way thru the u-joint and shaft, more than like likely a key shaft or two the u-joint slides on to.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 7:08pm
There is a nut holds the yoke that is the over running clutch onto the slip clutch. The slip clutch is half to the flywheel with three 3/8 bolts
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 3:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 3:47pm
It doesn't look like the nut can be removed with the U joint in place (unless a box end wrench will fit in there???).  Socket or open end wrench doesn't look like it will fit.
I did look at the 3 bolts holding the slip clutch to the flywheel - they will not come out all the way unless I take apart the slip clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 4:58pm
Are both pieces bent or just the piece that slides inside?
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 6:08pm
It will take a regular box end. Ratcheting version won’t fit. It will go round and round one way. Not the other. Don’t remember if removing or assembly was the easier way but it’s not bad at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2024 at 11:50pm
I modified a box wrench to fit...If too tight a crack with hammer and chisel.  Loosen the nut before any thing else...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 2:43pm
Don't know.  The shields aren't bent.  Once the shaft comes off, I will have to figure out how the shield comes off to see whether it is one section bent, or both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 3:53pm
Update:  15/16" Box end wrench was able to fit the nut on the flywheel and the shaft came off easily.  Next issue is removing the shields from each end of the shaft.  Parts book shows a snap ring by the U joint, but I have not seen it up close in person.  Anyone have any hints?
Edited by DSeries4 - 30 Oct 2024 at 3:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 9:43pm
On the shaft on the hood. There is a small slot near the support bag.  That is the snap ring slot. Push it in on all the slots and slide shield off. On the other side line up hole with the roll pin and drive out. The yoke will slide off the shaft and shield will slide off
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 8:19am
Next issue:  for reinstalling the shields over the shafts, how do you lock the snap ring into the 3 slots?
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 10:09am
Use a screwdriver to walk ring back into the guard. Then turn until detents pop into the slots. If you can line bumps up with slots it will snap in easier
This page was generated in 0.057 seconds.
