Hydraulic lift capacity D10 D12 D14 D17
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic lift capacity D10 D12 D14 D17
    Posted: 18 Oct 2024 at 4:47am
Hi
i an looking for the lift capacity of the old tractor.
What is the lift capacity for  D10 D12 D14 D17 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 6:40am
There never was (to my knowledge) an official lifting weight rating ever published.  I do know a D-17 series 1 will pick up a fully mounted 4 bottom plow and that could be as high as 1400 lbs with the rear bottom a long ways behind the tractor. A series 3 D-17 will lift more than a series 1 because of a larger lift ram. A series 4 will lift even more yet. A D-14 by comparison will lift an 800 lb plow. D-10/12 less than that. Every model, if their hydraulic system is 100% good, can lift enough to raise the front wheels off the ground without any front end weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 2:58pm
I have 1500 pound on a Plow hitch on the back of my D15 for counterbalance with the front end loader it will pick it up easily.
My  D10 series I and the CAs will lift 1000 pound on the Snap-Coupler Carry-All with sufficient front weights added
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 4:37pm
I had a "17-Series 3" and it would not lift a round bale from a Vermeer 605F baler. At least not to the point where you would feel safe with it. Not much lift capacity at all in my opinion. And this was dry grass hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 4:41pm
Steve, you bales could be 16-1700 # and the weight is quite a bit back from the hitch ... right ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 5:42pm
And, the 3700 psi hyd pump spec may have only been 2500 psi..........
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 6:16pm
MY D-14 could lift 3000# on the rear.
lift for a front end loader would depend on WHICH loader was installed
My loader D-14 would lift an 1800# pumpkin....
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2024 at 3:22am
For example on the English ED40  , the  manual says that the pressure is 2500 PSI, 5 gallons /mn   and lift capacity tested at 2300 lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2024 at 8:21am
What do you want to lift.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 8:38pm
they will lift alot more than they are meant to when the 70 year old pumps are freshened up  and make more than 1500 psi
