b-112
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: b-112
    Posted: 29 Oct 2024 at 8:46am
Would think all decks from B10 through B212 interchange. There was some of the B100s, B200s that had a double v deck drive belt. But think the shafts were the same if you had to change pulleys.
I’m not very good on simplicity models but I think they are called landlord and sovereign. 2110 2210 3012 3210 3212. And the decks would be the same.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 7:30am
I have never seen any difference between Allis and Simp. decks other than paint! I have some extra 42" decks if you are needing 1.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 7:22am
I have a HB-112. They use either a 42" deck or 48", L/H discharge.
G
https://www.tractordata.com/lawn-tractors/000/1/3/133-allis-chalmers-b-112.html
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 1:49pm
As far as I have known, the only difference between a Simplicity and an Allis was the colour scheme and Model Designation.
I suggest you join the Website SimpleTractors. It is designated to just Simplicity and Allis.
Gary
https://simpletractors.com/
ALLIS NUT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLIS NUT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 12:15pm
hello, just boughtb-112 garden tractor with snowblower, does anyone have info as to what simplicity model numbers for mower deck and roto-tiller would work on this mahine? also wondering if any truth to allis deck being different than simplicity being discharge chutes being on opposite side? thank you in advance for any info.
TERRA TIGER D-19 WC UNSTYLED WC STYLED WD-45 UC,rc,190,ca,7790,B10
