Just curious
rdean33422 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdean33422 Quote  Post ReplyReply Direct Link To This Post Topic: Just curious
    Posted: 12 Oct 2024 at 6:41pm
What year did they start putting distributors on WD tractors?
Thank you
Ray
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2024 at 6:53pm
I know my Dad's bent gearshift late 1952  or 1953 WD had factory distributor ignition. Not the add-on style that bolted up to the mag drive.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2024 at 8:48pm
My 50 WD has a mag.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2024 at 9:30pm
WD parts book indicates distributor began with sn 136318
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 6:01am
So that would be quite early in 1954.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 6:21am
We bought a 1952 new and it had a distributor.
J. Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 7:11am
WD-45 production started at chassis s/n 146607 in summer/fall of 1953. WD's started distributors at 136318 which is also 1953 and about 10,000 tractors before the WD-45 started. Looks like no battery ignitions in 1952 according to the parts book. Sometimes mistakes are made, but that's what it says.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 9:33am
I checked the CA Parts Catalog:
Generator, Electric Starter, and Distributor all started at Engine Ser. 149840.
Couldn't find any Tractor Serial Number to correspond to this Engine Serial.
Checked Bryan Smyths 'Tractor Ser. - Engine Serial reference
Year     Tractor SN Range     Engine SN Range
1950     14 - 321           140553 - 141017
1951     322 - 10538           141018 - 156449
1952     10539 - 22180           156450 - 174033
1953     22181 - 31423           174034 - 187993
That indicates about mid 1951 for CA Distributor.
Gary
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 10:06am
Dr.
Reading this Forums 'Serial Number Reference' Chart:
I get the same conclusion as WF.
1954 WD 1st 131243 last 160384, since early Serial Numbers posted are ending #s
   Ser. 136318 falls in this range, so a 1954.
BUT the 'Serial Num. Ref.' states "** WD-45 production began at 146607 in 1953"
Something is not right. perhaps WD-45 started in 1954 ?
I have a picture of myself sitting on a brand new WD-45, with another one parked in view behind it.
This would have been when my father first started with his Allis Chalmers Dealership.
Unfortunately there is no date on the picture.
G
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 11:23am
We like pictures
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 1:13pm
Me too Straa, but I never learned how to post pictures.
Guess I should learn.
G
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 7:11pm
Just random data add:
1952 WD WF 125xxx with distributor on mag mount (suspect dealer/aftermarket)
1952 WD NF built two weeks before with magneto
First is the one I have now, bought a few years back. The other was my father's that we had when I was a kid that my brother has currently.
We tried getting our father's running but got the mag gears indexed wrong and need to get back to it.
Edited by jvin248 - 13 Oct 2024 at 7:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 7:38pm
My 52 has a distributor. Would have to check to see what the S/n is
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdean33422 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 9:51pm
Thank you all for the replies
My serial number is some what messed up on my tractor so the best I can tell it is either a 1949 or a 1951.
WD with a magneto and a straight gear shift lever.
Thank you again
Ray
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 6:05am
This is all correct. Where the 1954 thing comes from I don't know. To expand a bit, the snap-coupler hitch became standard equipment at serial number 151381. I believe it was optional before that and many WD tractors have been retrofitted, I have one of those. Diesel engine production started at serial number 181341, 4 bolt wide front ends corresponding with this. I'm not 100% certain on this but pretty sure.
Couple other random thought on this as I'm paging through the bible; My Grandpa's WD that he bought new is 115xxx and came with a mag. and straight stick. It's still here but now has battery ignition I installed. On page 80 of Norm's bible there is a picture of a 45 with 15-28, (18.4x28) rice and cane tires that were a factory option. I mention this because there was some controversy at Hutch about my 16.9x28's being larger than "stock" tire size. There was also a diesel in the 5000 lb. farm stock with the same size tires. I don't remember him getting any flack about his tires but I digress. Maybe next year I should take the book with me and show them that picture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 6:19am
re: What year did they start putting distributors on WD tractors?
3 days after some engineer got out of the hospital with his busted up finger,wrist and shoulder ?
