AC 170 Gas crankshaft pulley install
AddictedtoAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AddictedtoAllis Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 Gas crankshaft pulley install
    Posted: 10 Oct 2024 at 11:44pm
Anyone have any advice or know the proper way to install a crankshaft pulley on an AC 170 gas crankshaft?
Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 5:42am
Nothing special to it.  Slide it on and run the setscrew into the dimple of the crank.  If the engine is still in the tractor, I'd about bet the steering pedestal has to come off first.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 5:56am
Be sure to get the set screw TIGHT so the pulley doesn't shake loose after a time. The pulley should fit the snout of the crankshaft slip fit tight. It cannot be loose on the crank. If so, I have a repair for that.
Edited by DrAllis - 11 Oct 2024 at 6:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AddictedtoAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 10:50pm
Thanks guys! Appreciate the quick reply!
