R62 8.3 fan pulley failure
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: R62 8.3 fan pulley failure
    Posted: 09 Oct 2024 at 9:09pm
Been running this machine since 21, last fall the pulley on the water pump/ fan failed. Cut into the the front cover a bit. Put new parts on from 8.3 Cummings and finished last fall. Yesterday the new pully failed. Exploded, again.
The radiator is clean, the machine runs in the low green in beans under load. We clean combine daily with air.
  What could be causing factory water pump/ fan pulley to fail.
Thanks LeonB
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 6:37am
Well 1st is the fan pulley, fan hub, or the water pump what failed. You have kinda talked in circles. The water pump doesn't have a replaceable pulley and doesn't carry the fan.
Edited by im4racin - 10 Oct 2024 at 6:38am
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 6:59am
That confused me somewhat too. From the cutting into the cover comment I'd guess water pump bearing went out.  As for a new one lasting under a year, assuming same mode of failure I'd suggest either belt tension way too high or major imbalance in the fan/hub assembly causing excessive vibration and killing the bearings.
But as mentioned, we need a little more specifics to really help further. What part failed last time (pulley that the belt rides on, fan/hub assembly that bolts on or the bearing in the water pump itself)?  And is it the same failure this time round?  Photos may also help if you're not 100% sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 7:27am
Were they new…from an 8.3 Cummins…?  That sounds used to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 9:54am
Local independent who cares for area Whites says the pulley eating the cover is common on that Cummins. Don't remember what failed to cause it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 10:24am
I did misspeak, it does not have anything to do with the water pump just the fan and the pulley for the ac. Yes the part we put on last year was from a Cummins dealer as is the one we just put on this morning. The center of the pulley breaks out around the bolt hole circle and then plays hell with the front cover until the belt shreds. Sounds like I may be replacing this pulley annually as a precautionary measure.
I will try to do a better job of blowing out and around the front of the engine when I do the rest of it.
Thanks guys
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 2:52pm
It's like they need a reinforced stamping to add on like the ole Chevys did
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 6:22pm
Some applications use a reinforcement ring on the pulley. If your Cummins distributor is like our local one…good luck!  It will take a competent parts guy to find it!  If I had a sn to use I would certainly offer it but no longer have the notes from when I worked there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 6:31pm
im4racin, thanks for the info. We will do some research on it and see if there is something available.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 10:43pm
I think I have one of the reinforcement rings but can’t seem to find it. If I run across it I will let you know if there is a number on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 8:20am
I do appreciate it
Leon B
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 9:18am
Leon B MO, Does AGCO offer any updates to this issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 10:55am
So we did a little searching around this morning while waiting for the beans to dry out. We found that Case IH had the 8.3 in a 2388 combine and it had the same issues that I had. Case IH made a replacement pulley that is one mm
thicker than the original. Everything else should be the same, bolt pattern and diameter. So we called our nearest Case IH dealer and ordered one, we'll see what it looks like when we get it.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 1:06pm
Save that number Leon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2024 at 1:41pm
Definitely Steve. And I will post here on outcome.
Leon B
