Wanted: 175 Air Cleaner Extension
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: 175 Air Cleaner Extension
    Posted: 09 Oct 2024 at 5:20pm
I have a 1980 175, and looking for the complete unit with pre-cleaner. Thanks in advance for any help.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 6:46pm
I have the filter housing, rubber filter cap and filter cover.
No band.
Will have to look for
pre-filter.
PM me your cell and I'll send you photos of what I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 7:32pm
I think he desires the above the hood "pre-cleaner" with the plastic bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 9:07pm
Yes, need the extension pipe through the hood, etc. thank you again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 8:23am
The pre-cleaner itself is the same for gas or diesel. The connecting air hose is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 6:30pm
Thank you Doc….guess I should have specified I have a diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 8:56pm
From my research I believe that was an option on 170, 175, 180 and 185's.
And unfortunately I do not have the above hood parts etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 10:02am
Thank you for checking.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2024 at 4:38pm
Do what you want, but personally, I don't like them. It obstructs visibility and the hood is not strong enough to support it. It will shake around and eventually crack the hood. I know there were reinforcement bands for them, and I'm sure it helps. They're really not necessary, unless you just like the way it looks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2024 at 4:04pm
Great point. Love the look, but I mostly use it for mowing so air filters are constantly being replaced. Too many dandelions lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2024 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2024 at 10:34am
Thank you, but already sold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 6:59am
Dang
Sorry about that.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 7:05am
For practical purposes you can always ty-wrap smaller type screen across the front of your front shroud.
Most of the dibris just falls of when the engine is shut off.
Easy to remove when not needed.
