65' Allis Chalmers 190xt throw out bearing
whizone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Topic: 65' Allis Chalmers 190xt throw out bearing
    Posted: 08 Oct 2024 at 9:22pm
All, can anyone tell me if you can grease or oil the tractors throw out bearing? Mine has been making a chirping noise for quite some time and sounds like it needs some grease or oil? Any ideas not related to a replacement..
Thanks,
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 8:42am
No it can't.  Time to split and replace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 10:14am
It's giving you fair warning. Better fix it before it starts cutting off fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 9:03pm
Strangely enough it stopped making noise today.  Thanks for help.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 9:22pm
That bearing shouldn't be spinning unless you are stepping on the clutch pedal. Make sure that you have some free play in the clutch pedal, by adjusting the rod. Once adjusted,spraying some oil on bearing, may help to get by until it can be properly serviced.
