d17,d19, 170 steering box output shaft seal
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Topic: d17,d19, 170 steering box output shaft seal
    Posted: 08 Oct 2024 at 12:08pm
seal that came out is 262fm124 C/R  looks to be unobtainium  the replacement  agco #70229966 or 229966 if that makes you feel better.  Seems the only seals  available are about half the thickness(.750 vs .313) and lack what looks like a felt portion. what replacement seals are you guys using? are you double stacking them?  filling it with  85-140 oil or 00 grease ?
i know i am overthinking this  but id like to keep the oil in it for as long as possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2024 at 12:31pm
Double stack two new seals and forget about it. You can't run anything heavy in that gearbox unless it's a 170 or D-series without power steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2024 at 2:04pm
tractor in question is a  early  170  gas  with loader
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 8:53am
You definitely CANNOT use grease in there!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 11:18am
This is the reservoir for your P-S fluid so, like the good doctor says, you can't put any type of grease in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2024 at 11:32am
On the mighty first generation One-Seventy's, the steering gearbox/bolster is just that...a gearbox. The power steering is getting its oil from the torque tube as it is a hydrostatic system with a triple section gear hydraulic pump hanging in the belt pulley hole..
