HD 5 Main Clutch
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Topic: HD 5 Main Clutch
    Posted: 05 Oct 2024 at 6:39pm
I recently bought a Hd 5 crawler. I'm looking for supplier of clutch parts a yoke # 053925.
Looking for information on removing the yoke.
Can it be done by leaving the housing in place or would you have to remove the part from the crawler?
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2024 at 8:32pm
I am not sure if you can removed the yoke with out removing the cluch belhousing and master cluch ,the yoke have a short shaft each side with key way
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 4:06pm
Remove bell housing , remove full clutch assembly , disassemble on bench and find the parts you need . I ended up turning the brass sleeve myself to replace worn one in my machine . Also check pins on the over-center linkages and the arms themselves for wear
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 5:53pm
Thankyou for quick response, on my question.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2024 at 6:57pm
The clutch friction material also needs to be checked and rivets holding it , the disc if it has dampening springs also need checking . I replaced a couple discs ad last time I went to bi-metallic disc . Same as the HD11 steering clutches I used rather than fiber discs .
 It may be necessary also to check flywheel and friction face of clutch to see if they need resurfacing .
 Replace the bearing in the crankshaft with new sealed bearing , making sure crankshaft wick fitting is plugged . Original pilot bearing was lubed from drilled hole in crank, by using sealed bearing no oil is introduced into clutch housing area .
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2024 at 10:20am
If you removed the belhousing and cluch assambly you need to removed the cluch bolts first
This page was generated in 0.085 seconds.
