Greasing the PTO universals in an AC Forty Five |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Thanks(1)
Topic: Greasing the PTO universals in an AC Forty FivePosted: 05 Oct 2024 at 3:48am |
The back three aren't so bad but the front one is a pain to get at from underneath. But there is a rectangular bump over it in the front left hand corner of the cab floor. And that has a squarish window cut out at the left hand rear. So, if you take a torch (flashlight) and check as you turn the engine over by hand, you will see the grease nipple appear in that window ready for access. Easier with two people but you work out where it lines up if on your own. I found that by accident, not in a manual. Edited by Ian Beale - 05 Oct 2024 at 3:51am |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42261 |
Posted: 10 Oct 2024 at 8:18pm |
Seems sometimes someone figured it out but never informed others of the solution.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8978 |
Posted: 22 Oct 2024 at 2:47pm |
Be nice if you could mark pulley so could see where to park it to lube.
Ian Beale
Posted: 22 Oct 2024 at 11:17pm |
You can mark the PTO drive pulley so you can see the mark from underneath while turning the engine slowly by hand.
I think you'd be lucky to get it positioned with the starter
