84 gleaner n6 mods
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 84 gleaner n6 mods
    Posted: 04 Oct 2024 at 5:48pm
Can someone point me in the right direction or someone to talk to to order the right parts to hyperize my n6. What combine are the channeled helicals from. Is all forward rasp bars the way to go?
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 7:27pm
I can help you a lot. "Hyperizing" isn't always the best way to go. Questions for you, because your answers dictate what would be the best way to change your combine. #1. Have you ever used this combine?? like you've just bought it and think you right away need to change everything there is ???  #2. What crops do you plan to harvest ???   #3. Are you all flat land or gently rolling hills or extreme hills ??  #4. How capable are you when it comes to fabrication and welding/repairs ?? #5. Do you have a forklift to remove the rotor ??   #6. Do you have any idea what has been done to the processor when it comes to concave/rock door/helical bars ???  #7. What are your performance expectations??   I have seen some combines ruined from too many unwarranted modifications. What works in one area/one crop doesn't always work somewhere else. This will be a good start.
Edited by DrAllis - 04 Oct 2024 at 8:15pm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2024 at 6:40am
I have an 84 N6 that I bought about 8-10 years ago. Have had really good luck with it. I bought it from the original owner, and when I worked at the dealership, it was the very first brand new combine that I did the pre-delivery inspection on. Then some years later, the guy brought it back to the dealership, and I went completely through it for him. Then years later he retired, I was needing a combine, and I was able to score it. I have a few ideas of things I would like to try to improve it, but nothing earth shattering.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2024 at 7:20am
If I was prepping a new 1984 N-series for corn/soybeans only, the following was done before it left the shop: #1. the rotor was pulled and two factory reverse bars were removed. #2. every other wire in the rear three rows of the concave were cut out with a torch. Short remaining wires were tack welded so they could not move. #3. the four helical bars on the dead bottom of the separator cage were removed. Then, a flat 3/8" thick by 1 inch wide crop bar was installed at 6 o'clock dead bottom of the cage. This flat bar tumbled the fodder to shake loose any trapped kernels so they would separate out thru the cage. #4. two extra rows of long helical bars over the top of the rear feed chain were installed (total of 4 extra bars) for constant crop transition under tough conditions. One or two short thresher helical were added in at the half-way point in the cage (with fabricated fasteners) to keep crop from going around the concave a second time. This is pretty important.  #5. a 3 inch tall wall about 12 to 15 inches long was welded to the front of the tailings auger trough to move over to the left any tailings return and to help move some % of grain more to the center of the machine due to the concave being more "open" with wires removed. This was a big help in steep side hills when leaning to the right.  6. On N-5 machines a cage cover was installed above the discharge paddles to keep loose grain from falling back into the cage and going out the straw chute. Keep 1 inch away from the cage and on top of the hoops. 12 o'clock down to 10 o'clock is enough coverage #7. Rotor RPM's were kept around 240-260 in corn and under 600 in soybeans. My rotor losses in corn were NEVER over 1 BPA and generally always less than .5 BPA.   #8. 1 5/8" long tooth square tip corn chaffer is a MUST with the front 8 rows independent of the rest of the chaffer. Run the front 8 rows a little wider than the rest. This was my "hyperizing" from 1982 thru the end of the P-1 processors in 1991.   Every new machine got this done to it. Every older customer machine eventually got these same things done. That's why we sold combines and had happy customers.  2000 to 2200 BPH in corn was max capacity in an N-6 or 7. With a 6-row corn head in 140-150 BPA corn it was usually as fast as 2nd gear would go...5.5 MPH all day long AND machine losses very very low.
Edited by DrAllis - 05 Oct 2024 at 7:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 7:06pm
Thank you for the useful information. Much appreciated.
Cory
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 10:49am
Old thread here Dr but I was wondering if that crop bar you refer to is an agco part or something that you fabricate yourself?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 4:20pm
Don't think crop bar was anything more than flat iron. Common thing was tu use a rasp concave bar from an F-F2-F3 as the trip bar. Don't remember if one was enough. I think Tbran came up with this idea. PM him. May be some reference to it on the combine site under "hyper mods"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 7:14pm
The official "flat crop bar" that bolts on the separator floor is 71326667. It requires 3/8" "plow" bolts to secure it thru square cage holes. Also, you'll need some homemade 3/8" flat strap about 2 inches long with a 3/8" hole to clamp it in the square hole. I finally started making my own out of flat strap (1/2" or 5/8" ? thick) 1.25" wide, drilling holes and tapping threads in the holes to eliminate plow bolts. Just thread in 3/8" gr 8 bolts from the bottom into the flat strap. There also a flow-retarder that makes the fodder take one more turn before discharge p/n 71338428. I don't know if any of this stuff is available any more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 7:54pm
Thank you both for the reply, yeah, I looked up those numbers. They are no longer available. Shouldn’t be a big deal to fabricate it up though..
robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 6:49am
The Combine Forum has a Post of Gleaner Hyper Mods on thier Website:
