On the hunt for a B&S Vanguard repair manual..
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: On the hunt for a B&S Vanguard repair manual..
    Posted: 04 Oct 2024 at 1:05am
 I am in need of a repair manual for an 18 HP V twin Vanguard Briggs And Stratton.
  Model=350447
  Type  = 1080-A1
  Code= 96012 411
 I've tried Ebay and Amazon but no luck so far,,,,?
 Anyone got an idee,,,??
Edited by desertjoe - 04 Oct 2024 at 4:40am
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 7:59am
  Model=350447
  Type  = 1080-A1
  Code= 96012 411
Just by chance Joe, is that engine in a Craftsman lawn tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:21am
your not going to get that SPECIFIC... All Vaanguard engines would be VERY similar and all in the same manual... 18- 20 -22 - 24 HP all the same ... verticala shaft / horizontal shaft... ... AMAZON..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:24am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:27am
manual part number 272144 your local mower shop should be able to get it for you list price  38.84
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:29am
  Model=350447
  Type  = 1080-A1
  Code= 96012 411
  Hey Lars,,I'm not sure,,most mower engines are verticle shaft,,the one I need is a horizontal shaft,,,Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:31am
Hey Steve,,I did look at this one,,but saw no mention of it covering the 350447 model,,,? Thanks,,!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:34am
 Thank you Hudco,,I'll look into this one,,,,Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:34am
I used to download manuals from B&S website...maybe you still can ??
BTW yours was made  Jan 24th 1996.
I've been told Vanguards are the 'top of the line', better bearings and such but a LOT of 'common' parts.
FYI the 'wires' connecting the coils to mag have  diodes inside the heat shrink. If one diode fails open, that cylinder will still run....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2024 at 8:37am
Joe, as good of a mechanic as your are, i doubt you even NEED a manual... I took a horizontal shaft motor 15 years ago and MODIFIED a couple parts to use it as a vertical shaft motor... I rebuilt it last week without a manual... Pretty basic.. When i had a question, i just looked at You Tube for some details.... ALL the vanguard engines will have the same pistons / cam / clearances / specs.... Usually they just changed the bore 1/8 inch to go from 16 -18-22 HP output.. You can adjust the governor to get 3000 - 3600 rpm max speed... really that is the ONLY difference in all the Vanguard engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2024 at 7:53am
  Well, Steve,,Many Thanks for the vote of confidence,,,,Clap  Most times if I disassemble one, I do pay close attention and  I can assemble it OK, and,,,,,and,,,I usually do find a place for all the nuts and bolts with no left overs,,,,LOL I do like to have access to any wiring diagrams tho as some shade tree'ers do tend to cut wires during their troubleshooting,,,,,Wink
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 7:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2024 at 8:01am
thats WAY over priced... I posted the same book from another vendor for 1/3 that price.. Same manual that HUD recommended.... there is only ONE BOOK that covers all those engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2024 at 9:42am
 That's correct Steve,,,and that one is the one I caught at a "Reduced" price sale for,,,,,,$12.00 plus $5.25 shipping,,,!!! Many Thanbks to you and Hud for all your help.
Ole Shameless did not call me "Thrifty" for nuttin,,,Wink
  Now I'm on the hunt for a manual for an Onan  CCK _5      _3F with SN of 510662353  (Those two missing numbers are not legible on tag)
 it is a horizontally opposed twin at 12.9 HP  @2700 RPM
 this one may be a real old TimerLOL
