Allis 6080 fuel issues
HoustonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoustonM Quote  Post ReplyReply Direct Link To This Post Topic: Allis 6080 fuel issues
    Posted: 29 Sep 2024 at 1:04pm
I have a 6080 we use to bale with, while using it this year it started idling higher and lower on its on and eventually dying. It wouldn’t start for a couple hours then once it did it would only run for a few minutes. Got it home and pulled the return fitting off and there was no junk or anything in it. Went ahead and ran a hose from the injector pump into a separate tank to rule out crud floating in the tank. It would just do the same thing. Hard to start and once it starts it’ll only run for about 5 minutes. The injector pump was rebuilt in 2020 at Cordell’s in Oklahoma. Any ideas would be welcomed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 1:18pm
Outlet to the fuel tank plugged.
Post Options Post Options   Thanks (1) Thanks(1)   Quote HoustonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 2:41pm
Thanks for the help. Blew the line out and the tractor seemed to start easier. It ran about 10 minutes before spitting and sputtering before dying again. That’s the longest it’s ran so far. I took the return line off and ran a clear hose into an empty bucket just in case that line was just plugging back off. It started right up again and did the same thing. Ran about 10 minutes and started sputtering erratically before dying.
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 2:54pm
So you have (I assume) eliminated both supply and return lines as part of the problem. What's left other than the pump, regardless of when it was rebuilt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoustonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 3:19pm
That’s where I’m at with it also. Was just picking some brains that know a little more than I do. I’m a welder and not a diesel mechanic haha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 3:28pm
On the side of the injection pump is a small rectangular cover with two slotted screws in it. Use a flat blade screwdriver and when it starts to act up loosen each screw a little until it begins to leak fuel and see if that straightens it out. You did remove the tanks outlet fitting and KNOW the fuel can gravity feed out of the tank easily ??
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 4:27pm
you need to take the actual return fitting regulator out of top of pump, it's the 1/8" pipe thread hex piece that screws right into the pump top cover. That check ball is likely plugging up, or somewhere down the line is plugging up between there and the tank. Possibly left over debris from the last failure? The aftermarket kit flex rings seem to only last a year or 2 as well. Most of the big shops like to build in their future work lol! Ope! it's out of warranty. Hope not.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 8:08am
The fuel outlet in the lower right hand corner of the tank can get restricted on those tractors. Shut the fuel off at the fitting and remove the hose there. Now open the shut off and see what kind if flow you have. If it's slow, have a buddy close by air pressure. Take the fitting out and while you hold your finger over the tank outlet,have you friend blow that fitting out. It's still a messy job regardless of how quick you do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoustonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2024 at 2:45pm
Yep, sometimes it’s the simple things! Had some black tar looking crud in the valve on the bottom of the tank. Thanks for all the help guys! Tractor ran good for around 2 hours last night. Pumped the tank out and now it’s getting a good cleaning!
