AC wagon hoist options
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: AC wagon hoist options
    Posted: 27 Sep 2024 at 6:57am
The following photo shows the AC wagon hoist options from an Allis-Chalmers Running Gears sales brochure FE-379 668(Farm Equipment Division 379 1966 August).
Upon reading this, I'm assuming the flare boxes received the High Lift 56" hoist & the barge boxes got the Extra High Lift 84" hoist?  Also, I did not realize the 3" versus 5" hoist cylinder options. Guessing the older AC tractors (WC, WD, WD45, D14, early D17s, & D19s)with high pressure/low volume hydraulics would have been paired with the 3" hoist cylinder? Later AC tractors(D17IV, 100 series, etc) with lower hydraulic pressure/high volume systems would have been paired with the 5" hoist cylinder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 7:45pm
I have one I want to mount on an AC running gear. Need a couple of brackets. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 6:48am
check your pm. I’m sending you a link about it.
