Won’t stay running…
Old School AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Topic: Won’t stay running…
    Posted: 26 Sep 2024 at 8:38pm
I have an old d15, I believe it’s a 1962. The positive battery post touched and grounded the engine out…burnt the ground post off. I replaced battery end but now tractor won’t stay running. Runs for 1-2 minutes then shuts off. Any suggestions????
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 9:00pm
well with a shorted out battery cable, its probably not a fuel problem.. Electrical area... Coil , capacitor, starter key/ switch, wires...... When it dies, see if you have 12v at the COIL... if you do, then the battery / switch / key / wires are probably working right...
12v power to the coil , then check the FIRE at a spark plug.. If no SPARK, then you have a coil or capacitor or burn point problem... If you have NO POWER to the coil, then look at the key switch and the wire from the key to the coil.
--------One test is to take a jumper wire from the battery to the + terminal on the coil and then start the tractor.. That bypasses the key and wire harness to guarantee you have POWER to the coil.
Edited by steve(ill) - 26 Sep 2024 at 9:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 9:59pm
A model D-15 gas with a generator is a POSITIVE ground. So, how can the ground short out ??   Or, do you have an alternator conversion and now it is a NEGATIVE ground ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 9:16am
Yes it runs on gas. I have an alternator with a separate Solenoid. The solenoid positive end touched the frame and the negative end melted from the battery. Yeah, yeah
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 9:23am
Thanks Steve, I will try it this morning to see what happens. I’ll reach back out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 12:46pm
once you get it going, you might find out the alternator has a problem... Solid state parts inside do NOT like shorts or sparks..... hope for the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2024 at 11:09pm
Can’t get it to run correctly. I don’t know if coil, points, or carburetor is needed. I have no idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 6:27am
Original complaint was it only runs for 1 to 2 minutes and quits. Now, the complaint is you "can't get it to run correctly".  So does it now run all the time?? just not running smoothly?? or does it still quit every 1 to 2 minutes. Shouldn't be the carb because there wasn't any problem prior to the electrical meltdown, correct ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 8:30am
I changed the coil yesterday because while running a few minutes with the choke almost fully engaged coil was so hot, you couldn’t touch it with you bare hand. It will run for a few minutes with choke engaged but will sputter then die out. I did open the carburetor to clean it. Points, plugs, wires, starter solenoid, little white element that connects to coil? I don’t know which way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 8:35am
that "littlel white element" that connects to the coil is not needed. That is a RESISTOR that lets you use a 6 v coil on a 12v tractor... Make sure your COIL says "12v with internal 3 ohm resistor", and then throw that little white thing away !
Edited by steve(ill) - 28 Sep 2024 at 8:39am
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 9:20am
Overheating coil indicates replacement is needed.
If a coil you get (scrounged from old bin) is poorly marked, you can use an ohm meter to measure the coil. 3ohm has the resistor block inside, low ohm has none and use the block.
External resistor block just like the external regulator cubes (instead of inside the alternator) just creates more connections to corrode over time.
If stuff got cooked, be sure and investigate wire runs and bundles. I just replaced generator wires on my WD since the insulation in a spot was so sketchy and the wires fragile. Then I found the main bundle was sketchy too and more wires. All running again though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 8:12pm
Do you think that I should change the points?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 8:40pm
Back in their day, points replacement was an every 500 hrs maintenance item. The quality of today's points/condenser parts isn't good. I normally wouldn't replace the condenser if the tractor was running OK. Not sure you have a choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 8:56pm
why are you looking at the point ?  Did you  get a 12v coil ?  Did you eliminate the old ignition resistor for 6V coil ?   First if would not run.. then you put " an old coil" and it will run for a few minutes, but not very good.... ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old School AC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 10:09pm
I put a new coil and new resistor (that square thing). Still won’t stay running. Maybe the carb is not good?!?! I did disassemble and clean it. Seems to be a very simple carb. I just don’t know. I’m just trying things for myself with me knowing that I’m not a mechanic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2024 at 10:26pm
Is the NEW COIL a 6v or 12 V ???
You DONT NEED THE WHITE THING (resistor) with a GOOD 12v coil.... take the resistor out and run the POWER WIRE straight to the coil + terminal..
Edited by steve(ill) - 29 Sep 2024 at 10:28pm
