Hd5
archangel_cpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Topic: Hd5
    Posted: 25 Sep 2024 at 6:03pm
Looking to grab this for some farm dozer work what are the groups thoughts??? https://www.facebook.com/share/Pqm2eEDrGBEs9vmz/?mibextid=kL3p88
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 9:21am
HD5B - had one like that - for your own work on site will work IF
Slow , underpowered at 48 HP for a 10' blade , even turned the blade would cause problems transporting on roads to any jobsite .
I converted mine to 2 - hyd cylinders mounted to bull nose rather than geometry shown
With a PTO could work for other uses .
Price - High - sold mine for 1/2 that many years back
Replaced it with a FA FD5 with 6 way blade and 80 HP power shift
My HD5G loader could push more material than the dozer could as less resistance from bucket than 10' blade
Parts can be found - EXCEPT undercarriage - track is made of unobtainium new and almost any good ones used
Edited by Coke-in-MN - 26 Sep 2024 at 9:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 9:29pm
Lowest he'd go is 3800 it seems steep to me when I can get a cat d7 or 6 cable dozer in pretty good shape for 8k literally 2 or 3x the dozer... I am worried about parts of something went wrong... the 271 is a dime a dozen but everything else??? I may go look at it but I can't figure out why AC didn't stick a 371 in the thing 271 does seem underpowered???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2024 at 10:12pm
Early HD7 had the 3-71 and HD5A machines made for farm use were repowered with the 3-71 by owners for field work . With the short track they also bob a lot when holding grade .  If one were to reduce blade width it would be a better machine , along with making power angle on blade using the present center as pivot - but a lot of work making those changes .
 I bought the HD5B after I sold my D6-9U Cat as that was a money pit - even though it was a hydraulic lift blade . No angle dozing and tilting blade was manual screws on frame .
 Early models were single speed reverse , with 5 fwd .
HD5G loader with a 2-71 is fine and I used mine for years digging basements, loading trucks , leveling lots , putting in roads and driveways . Dug a couple basements under houses that were blocked up as overall height was low enough to get under house and push out material for larger machine to move
 In hard or compacted soil that blade will not dig in , in light material it will work but slow . Check pins and bushings along with sprocket wear , also if truck frame is straight .
 When I bought my 5B it had broken axle and blower was seized as water froze and cracked lobe from drain plug hole in blower was closed off
This page was generated in 0.085 seconds.
