Allis Chalmers 190xt power director mystery.
Allis Eli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Eli Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 190xt power director mystery.
    Posted: 22 Sep 2024 at 3:48pm
hey everyone had a question on my 190XT
the tractor does not pop out of gear when driven and high and low works but once I shut the engine off it will
sorta roll forward does not matter what gear its in or if high of low is engaged it just will roll a few feet and then
stop. the engine is not spinning I have the foot clutch engaged and I will disengage it and then apply brake shut
off engine then let it out and let off the brakes and it will roll. going down a hill I will pull it to low and it will slow it
down same high also holds back. so I am sorta lost. does the engine need to be running for the tractor clutch to
be engaged? my other XT or my 190 standard never act like this
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 4:36pm
ALL One-Ninety and One-Ninety XT tractors have a hydraulic applied Power Director clutch. If you park any of them on a steep hill, leave them in ANY gear with the Power Director clutch in LOW or HIGH range, and shut the engine off with your foot off the clutch pedal, in a few seconds that tractor will roll down the hill into the ditch or creek or barn. Whatever is in the way will get run over. If that particular tractor doesn't roll down the hill, you must have badly warped or broken drive discs inside the Power Director clutch, not giving you a true neutral so it can roll down the hill. The BRAKE LOCK is there for a reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Eli Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 4:49pm
okay thanks for the info. it roll even on a tiny incline. all my other ones would roll if you pushed them I just thought it was strange that there is no resistance on this one at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 5:03pm
You also CANNOT PULL START any of these tractors.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2024 at 9:07am
In the hills of Middle Tn I would always see an old like 450 IH backed up a steep incline - I figured it was to roll start it.  One day traveling I noticed a 190 AC backed up the same inclined parking spot. When we came back I saw a wrecker pulling it out of the ditch about 100 yards down hill... Doc is correct about pull starting as this guy found out. (combine this with bad brakes and.....)
