AC 16 inch wheel for #4 plow
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Topic: AC 16 inch wheel for #4 plow
    Posted: 22 Sep 2024 at 9:05am
I can’t find a tire with the aspect ratio to set the deepth of my number 4 plow . I’m using a 4.7 16 motorcycle tire with the ac rim 3 inch wide. I’m still going to deep.
Is there a 4 or 4.5 16 inch rim I can use a 5.5 or 6 16 tire to get the diameter taller to get less deepth ?
Can’t get furrowed to lay down , more stacked or vertical now , best I can explain the issue .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2024 at 9:36am
Have you tried one of the temporary spares? I use them for implement tires on everything.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 6:11am
Is it a 5 bolt hub? There are thousands of WD rims out there with 5.50x16's on them.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 6:31am
Three rib 5.00-16 tires are around $60. Most any tire dealer should be able to get you one.
As for the dirt not flipping over into the furrow, speed might be your issue. Most plows don't work very well at slow speeds.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 8:52am
Example video from a good plowing setup channel. I'd sort through other videos he has. A lot of good information largely lost as small farms and small plows disappeared over the decades.
