TUBE ASSEMBLY 229367 D19
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: TUBE ASSEMBLY 229367 D19
    Posted: 20 Sep 2024 at 10:43am
Wanted one Tube assembly 229367 for D19  item 1 on page 195 of D19 March 1964 dealers parts book.
This is one of the lines for power steering.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 12:25pm
Checked all my sources, NLA - no NOS... D15D D17 D19 all use this , sorry.. looks like inverted male flare - either make one or salvage yards.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 12:56pm
If there’s enough straight section of tube on both ends you could get compression fittings that then crimp to hydraulic hose to get it made.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 4:25pm
I had to cut the tube above the 90 degree bend to put a socket on to get the fitting out.
Tube was leaking at other end. Had a hose made up but the fitting was too long causing the hose to rub the steering and radius rods.
