AC industrial with back hoe
ralack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ralack Quote  Post ReplyReply Direct Link To This Post Topic: AC industrial with back hoe
    Posted: 19 Sep 2024 at 1:28pm
I recently purchased a AC either d14 or d15 industrial with back hoe, can’t find serial number to verify but it does have the early 149 cubic engine. My problem is when I bought it and was shown the function of the backhoe I thought the guy moved a lever on the loader side to engage the backhoe but can’t figure it out. The guy I bought it since moved so no contact. Any help appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 8:41pm
It probably uses a DIVERTER valve to transfer hydraulics from loader to backhoe function . It's a common item on many older machines  to split the hydraulic pump flow to attachments - My HD4 used that so loader bucket had to be placed onto solid ground , then switch to hoe operation . Kind of a job to do more than one function with one end of machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote ralack Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 9:47pm
by chance would you know what that valve would look like? There is a t valve back by the backhoe, next time home I will give that a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 11:27pm
Probably yes , 3 ports on the valve power in , loader supply , backhoe supply .
The loader and the backhoe may each have their own relief valve also
 On my detachable hoe I also had a separate hose that connected to crawler and backhoe as a return line - you may mot have that if hoe is mounted to tractor .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 4:11am
IIRR, diverter blocks use BIG hoses.  So follow the big hoses to the diverter...Wink
This page was generated in 0.085 seconds.
