DrAllis |
MrSnerdly
Joined: 11 Jan 2024 Location: fairbury ne Points: 79 |
Topic: DrAllisPosted: 18 Sep 2024 at 2:41pm |
Edited by MrSnerdly - 18 Sep 2024 at 2:43pm |
MrSnerdly
Posted: 18 Sep 2024 at 2:45pm |
Is this the line? Having a hell of a time with getting the pictures right.
DrAllis
Posted: 18 Sep 2024 at 4:03pm |
YES !!!!!
MrSnerdly
Posted: 18 Sep 2024 at 5:28pm |
I don't see how you could put a fitting in there and get the line attached again. Would you have to make a new line? If I could make it work with drilling a hole in the end plate on the valve stack for the signal line I think it would be far easier.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88642 |
Posted: 18 Sep 2024 at 5:42pm |
some cases, you disconnect the line and use a HOSE temporary to connect up wth the TEE and gauge.. Routing is not important for the test... just run it out in the open.
