Allis-Chalmers 5040 Stuck rear end
Robller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robller Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers 5040 Stuck rear end
    Posted: 18 Sep 2024 at 2:13pm
I have a 5040 which we are rebuilding. The engine is now complete, and all put back together. When we fired it up and drive it around the rear wheels locked up with 1/4 turn in either direction. When I took the wheels off the hubs rotate without locking up. It is more like a hard stop that occurs with the wheels on. So freely turning without the rear wheels on and stops at 1/4 turn with the wheels on.
I have had it both in and out of gear and the only change is if the wheels are on or they are not on. I can't imagine that the lug bolts cause a problem or the weight of the wheels. There seems to be something in the axle area between the hub and the differential.
I hope someone has an idea about this before I have to do a lot of work that probably isn't required.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2024 at 4:40pm
So it sounds like the wheel Is catching on something. You should be able to figure that out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2024 at 8:02pm
Are the lug nuts the proper ones for this tractor? May be too long?
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2024 at 9:00pm
“When I take the wheels off”…do you have both sides off at the same time?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 8:47am
Did you have the wheels off when rebuilding the engine . How was it when parked to work on it . What all did you do to tractor .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 9:20am
There is something in the axle housing where the hard hit sound comes from.  Someone else asked about the lug bolts and the ones we have are what have been in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 9:24am
The wheels were on when the engine was rebuilt.  The clutch was replaced but nothing in the rear end.  Changed oil.  This is a new to us tractor that had 800 hours. It had been sitting outside and water ended up in the engine.  We bought it knowing there would be some issues.  We have a same model for spare parts.  We have a vineyard and there is a specific piece of tilling and hedging equipment that matches to the mounts which is why we bought a duplicate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 9:25am
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 9:26am
I am not certain as to if the tractor was moved ie rolled when the engine was rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 10:47am
Have you tried jacking the rear of the tractor off the ground and rotating the tires by hand without the engine running and the transmission in neutral? Sounds like it may be the differential?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 10:53am
Yes.  We have had it up on blocks with and without tires.  It rotates 1/4 turn in either direction with the tires on and there is not an issue with the tires off.  It is out of gear and the engine is not running.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 11:48am
Run the lug bolts in when the wheels are off and see if the hubs turn then,betting they won't
