2009 Ford Explorer
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: 2009 Ford Explorer
    Posted: 13 Sep 2024 at 8:56pm
‘Tire Sensor Fault’ comes and goes. Sometimes will stay on for an hour, sometimes 10 minutes, sometimes all day. Would this be one of the sensors in a tire? Have this vehicle over 10 years, just started do this a couple days ago. All tires are at the proper psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 9:00pm
YES.. each tire has a sensor.... each sends a signal to the computer.. If the pressure falls below 20 psi( example) then you get the  "LIGHT".... Each sensor has a small battery to keep it going.  Your batteries are 15 years old... Possibly that is the problem.
Bverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 1:23am
We have an 07 explorer that did this. We replaced sensors and it still did it. A month or two later dome light would occasionally come on when driving due to the ignition switch getting bad. I replaced ignition switch and lo and behold tire pressure sensor fault never came back on! Asked a mechanic at the dealership about it and he saw the same thing once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 4:43am
So many electronic boxes in the after 2005 cars, gets worse as move up in years as with our 2017 Exploder
Ford tech here noted are Seven in ours were four in you all’s and as of today 12 in newest. All dependent on power from a connectivity unit. You are lucky as to have a key switch, ours is Fob to Push button, a central ECM handles ours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 7:00am
Aren't all these computer controlled gadgets in newer cars wonderful when they start acting up?Wacko  Any vehicle ne enough to have a computer controlling everything is not anything I want. The vehicles I have will out last me, so I'll never be wanting a NEW vehicle. One big reason that everything now is controlled by a computer is the end goal of having idiot proof vehicles. case in point: Tire inflation sensors, I check my tire at least weekly with a gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 7:04am
Another reason I reworked my '99 SD F250 and the '05KW, has only ONE ECM, has a small Rear ABS Module under the hood on the SD, the KW has one ECM and a ABS Module in the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2024 at 8:26am
ABS=All Brakes Suck. the 2 things I own that had ABS when new have has the ABS control unit removed. I first became familiar with ABS systems in the 70s with the 121 standard. They were OK for the first year or so, but after that you never knew if you would have brakes when you pushed the peddle or not. That system probably caused more accidents than it prevented. When look looking at semi trailers I discard anything new enough that the brake controls can not be replaced with old style non ABS controls.
