WD 45 hyd.?
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 hyd.?
    Posted: 03 Nov 2010 at 11:09pm
I don't know much about the 45 hyd , but mine started to raise, then stop, drop it a little & lift it again & it'll lift some more. do this a few times Until It's raised up all the way up & seems to work fine . I'm using it to lift big round bales. It has plenty of power to lift the bales. Could it be some dirt in there or would it be a valve sticking? It seems that every time you use it does it at first but then works fine afterward. I'm picking your minds. Any help would be appreciated ,thanks Bruce
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 6:27am
Low fluid, water in fluid, fluid foaming?  Just a stab in the dark.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 7:46am
It's full, I changed it with iso 46 hydro trans fluid. thats what I've been using all along, before this started, thanks greg.
