L3 combine header hyd problem
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: L3 combine header hyd problem
    Posted: 10 Sep 2024 at 1:46pm
My pickup on the header does not turn anymore. Last few years I would change the drive motor and it would work again, but not this time.
The oil in the system gets too hot!
The hyd pump must be worn and recirculating the oil?
Any suggestions? I don't think Agco sells the pump anymore?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2024 at 9:15am
Tore down pump, everything was good except the bushings on the end cap of the pump. 1400 hours on separator seemed like low hours for failure.
Agco parts persons have difficulty finding it because pickup headers are not listed in their parts books and there is no model number on a pickup header.
This takes you to a wrecker or a hyd shop.
The pump is made by Cessna - company owned by Eaton. The pump is discontinued in this configuration - having end ports as compared to side porting. If you're lucky you can get another similar new pump and just swap the end cover with your correct ports. Then you're good to go.
