7040 losing prime
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: 7040 losing prime
    Posted: 09 Sep 2024 at 8:10pm
My 1975 7040 just recently started losing its fuel prime if it sits for a couple weeks or more. I have to pump the primer and then it will start. It runs fine once started and if it's only a few days in between it will start fine. The primer plunger was replaced with a new one a couple of years ago.  Any idea what would be causing this?  Thanks.
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 8:45pm
I had same issue. I had to change tank to pump supply hose. Didn’t leak fuel but sucked in air. Learned that on this site. Hose I removed looked good but haven’t had to prime it for 7 or 8 years since changing it. They deteriorate and let just enough air in to drain back and lose prime.
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2024 at 10:34am
my 7060 is with issues too
my prime plunger rubber disintegrate.   I was able to source a new plunger from the "Local" (45min drive) dealer, for just under $100.  They said they couldn't get the rubber separate.
now, when I prime, I can hear air coming out the pump.
I'm looking into getting the seals/gaskets for the pump and replace them.
it runs, but is rough with no load and from idle to 2/3 throttle.
once under load running PTO/RPM, it seems to run OK, with the frequent pulses....
only have one so no time to tear into it right now.
AC7060Pd 1975
