Adding a led light |
Ben (MI)
Joined: 02 Jun 2010 Location: SW Lower MI Points: 769 |
Topic: Adding a led lightPosted: 31 Aug 2024 at 9:54am |
Hello, I need a new bin light on the F3. I have a 30 watt led light I would like to use. The old light had only one wire. The new light has two wires. Should I connect the red wire to existing hot wire and attach the black wire the combine as a ground? I see where people have problems replacing incandescent lights with LEDs, I am trying to to avoid that. Any help is greatly appreciated. Thanks.
Part time farming with a 1980 7060 and 1984 F3 hydro.
dfwallis
Posted: 31 Aug 2024 at 12:15pm |
Not knowing the specific LED, if it is designed to operate directly off of the battery voltage (meaning it has the appropriate LED buffering circuitry internal to the package), then yes, the ground/black wire could be attached to the ground/frame (assuming negative ground). Some LED packages are lightbulbs that fit exactly in the old bulb fixture as-is. Of course, a bare LED would require you to add external circuitry to adjust voltage and current to the LED specs.
Edited by dfwallis - 31 Aug 2024 at 12:15pm |
1952 CA13092
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88642 |
Posted: 31 Aug 2024 at 12:20pm |
should be fine.. for a quick test, just touch the red wire to the HOT and touch the black to a bare spot on the frame.. If all is well, then go ahead and do permanent install.
Ben (MI)
Posted: 31 Aug 2024 at 1:12pm |
Thank you guys. I didn't do a good job of explaining, it's a work light that bolts on, not a bulb. I will give I a try as Steve suggested, thanks again.
nanuk
Joined: 22 Aug 2013 Location: Saskatchewan Points: 258 |
Posted: 01 Sep 2024 at 1:05pm |
I have had some LEDs that have two black wires.... crazy.
so I just use a 12v adapter with very low amps, and try to find the hot wire, and mark it. LEDs won't work backwards.
AC7060Pd 1975
Ben (MI)
Posted: 02 Sep 2024 at 6:35pm |
Thanks nanuk, I have it working, for now anyway.
