curputer updates
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Topic: curputer updates
    Posted: 29 Aug 2024 at 1:58pm
     Just wondering if everyone else has the same issue with updates to their computer. My Windows gets really, really slow, to the point of almost not working, when there is an update waiting. If I do the update everything is fine. Is there any easy way to bypass the updates? I usually don't see anything being changed but maybe they can better track my activity or some other use I don't know about. Any thoughts? Why can't they just leave things alone? Seems to happen every 1-2 weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 2:43pm
Google 'stopupdates' !!
I installed it on this Win10 machine years ago.... as there's no need for the OS to be updated.
I've also stopped all 'apps' from updating as well.
Only the AV database gets autoupdated.
Edited by jaybmiller - 29 Aug 2024 at 2:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 4:22pm
you might also do a "DISC CLEANUP".... maybe in CONTROL PANEL area..... If you dont cleanup every month, things tend to pile up and slow down the computer..
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 7:34pm
Thanks guys. I'll see if I can figure something out. I'm  bit on the technologically challenged side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 7:42pm
are you running WIN 7 , 10, or 11 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 1:18am
I run CC Cleaner (free version)  about every other week and also use Spybot Search and Destroy (free version) to remove or clean up some .
Advance System care  (free version) also does cleanup
