need help wd mag problems?
briangroc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briangroc Quote  Post ReplyReply Direct Link To This Post Topic: need help wd mag problems?
    Posted: 03 Nov 2010 at 10:44am
ok
new plugs .025 gap
new wires solid core
tractor fires rite up, but has no power under load
when you pull the wire off the plug when running the 2 center spark plugs: there is no change in the tractor idle( not firing)
the 2 outside plugs you can here a change in the engine idle when removed
when i pulled the 2 center plugs there was fuel on them
Mag is not working properly? can i have it re built or what do you recommend
guys thanks for the help   Brian
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 11:17am
Sounds like your new plug wires are not in the right order. Firing order for your tractor is; 1 2 4 3, not the more common 1 3 4 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 12:02pm
Verify firing order is correct like Phil says. If the wires are on right, move spark plugs and see if the misfire follows them. Champion plugs, in my experience, have no quality control. I have found them to have many more instances of defects than all others combined. If it's not the plugs, move the wires. When you removed the wires from the cyls that are not contributing, did they have a strong blue spark when held near the engine?
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 1:28pm
Brian - Have you tried reversing plug wire 2 & 3.  You do know that the mag runs CW as viewed from the cap end. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote briangroc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 1:04am
i will try reversing the plugs this morning.
i think mag because tractor was running great for 3 years.
one day it was just running really rough, so i changed the plugs and wires
and same thing still happening.
Thanks guys
This page was generated in 0.223 seconds.
