Was there maroon under black?
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: Was there maroon under black?
    Posted: 27 Aug 2024 at 8:53am
Did 7045's use a maroon primer under black paint? I see many with exposed maroon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 10:11am
So, check the chassis serial number just above the PTO shield. It should say 7045-xxxx. If it does, I guess you are seeing brown primer paint. If the s/n says 7030 or 7040, it's a maroon tractor painted black.
